checksum of .bit file
hi all,
i have one design made by one of my friend in vivado 2017.1. i copied it to my system and recompiled (vivado 2017.1) without any changes. but when i calculated the check sums of bit files they were different.
what can be the reason? i tried it 2-3 times.
how the checksum calculation is made? what are the factors which can affect the checksum? will it depend the tool version?
thanks in advance,
regards,
reshma
Re: checksum of .bit file
are the two systems are having same OS? and does the vivado settings for synthesis/implementation remain same in both the systems? you can check the implemented reports to see if they are same.
Please check this AR https://www.xilinx.com/support/answers/61599.html as well.
