compatibility of XILINX FPGAs with PSPICE
Good morning, everyone,
I have the VIVADO 2017.2. Is it possible to find a version of PSPICE that is compatible with this XILINX application. Such that the bitstream files can be loaded into the available FPGA and simulated.
Thank you in advance for your availability.
Re: compatibility of XILINX FPGAs with PSPICE
I am not sure what version of PSPICE would be supported. Generally all the 3rd party supported tools are listed in Vivado release notes. Check page#10 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf
You can always download the bitstream via Vivado and run the ILA to debug the designs. If you can check with PSPICE then it would be good.
Harshit
Harshit
