error on pragramming bbram in vivado
I'm using a ZYNQ 7z015 board and I try  to program an AES key into the BBRAM with Vivado. Very occasionnaly it can work, but most of the time I just get the following error:
What does this mean? How can I fix it?
I have tried Vivado 2017.1 and 2018.2, both with no luck.
Here is my operation snap:
Any suggestions are appreciated.
Re: error on pragramming bbram in vivado
Hi @damofeixue2008
While configuring FPGA reduce JTAG CLK frequency (For e.g. 3Mhz) and check.
Try using different JTAG cable.
Bhushan
Bhushan
Hi @bpatil
Thanks for the quick reply.
Where can I change the JTAG CLK frequency?
Hi @damofeixue2008
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug908-vivado-programming-debugging.pdf (Page 35)
Below command can be used to change the JTAG frequency.
set_property PARAM.FREQUENCY 3000000 [get_hw_targets */xilinx_tcf/Digilent/210203339395A]
Bhushan
Bhushan
Hi @damofeixue2008
Did your issue resolved?
You can also refer to AR63206 for your issue.
Bhushan
Bhushan
