if we mentioned IOSTANDARD in the xdc , Exactly what tool will do with this ?
Hi Friends,
1) When Loading bitstream will that do any IO configuration ?
2) what is the purpose of mentioning this ? For Internal design analysis while implementing ?
Any suggestions or help is highly appreciated.
Thank You
S Sampath
Re: if we mentioned IOSTANDARD in the xdc , Exactly what tool will do with this ?
Hi @ssampath.
The PMBus usage would be a question might be better suited for the 7 Series FPGA or Configuration boards. For Implementation flow purposes, it is required to be set by the user to a non-default value.
Hi @ssampath.
The IOSTANDARD would set the ports physical signaling standard such as LVDS or LVCMOS18. The SelectIO Guide has more information on each standard available. The property/constraint is then applied to the package pin.
http://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf#page=47
HI @marcb,
Thank You,
My doubt is, using PMBUS we will configure all BANKS IO voltages. what is the use of mentioning IO standard in the vivado ?
For example:
I have configured all BANKS in the FPGA to LVCMOS18 using PMBUS. if i implement design with IOSTANDARD LVCOMS25 then what will happen ?
I Hope you understand my question.
Hi @ssampath.
