Visitor eholtzclaw
list_property command
From XAPP1233, page 17
"list_property_value BITSTREAM.CONFIG.CONFIGRATE [current_design]"
What needs to be entered for [current_design]?
>>Eric
Re: list_property command
Hi @eholtzclaw ,
Application note mentions that you need to run this command with an open synthesized or implemented design for the target FPGA. So current_design here refers to either open synthesized or implemented design. [current_design] will be anyway replaced by tool with synthesized or implemented design name (whichever is open).
Ashish
Scholar dpaul24
@eholtzclaw,
You can leave it to current_design
set_property BITSTREAM.CONFIG.CONFIGRATE 66 [current_design]
This is what we are doing when using set_property CONFIG_MODE SPIx2 [current_design]
FPGA enthusiast!
All PMs will be ignored
Hi @eholtzclaw ,
Ashish
