Visitor ebi1359
spartan3 an program error
Hi dears,
I have a board with spartan3-700an.As you now spartan3-an series have internal flash.when I am going to program FPGA only in Impact some times it is not programmed and I have a message that "Done pin did not go high" in this time when I am going to program internal flash I have this message "error shows in the status register, CRC Error Bit is NOT 0".these errors appear some times not every time.
Can you help me about this problem
thanks
Re: spartan3 an program error
Hi @ebi1359,
CRC errors are typically due to clocking or SI issues on the board.
If a CRC error occurs, try slowing down the configuration speed(try reducing it to 3MHz or below), or investigating the SI characteristics of the configuration signals (in particular, the clock line).
Refer this AR#24024, for more information and how to debug the issue through Status Register values.
Deepak D N
Please Reply or Give Kudo or mark it as an Accepted Solution.
can you provide the log file for the both the scenarios
can you check mode pins and VS pins are set according to the requirement for ISF configuration mentioned in UG332
Visitor ebi1359
my mode pins are in correct state(0,1,1 for internal flash) but my vs pins are connected to I/O's without pull up or pull down.
ok, variant select pins should be either 101 or 111 as mentioned in table 10-2 during configuration. other condtions will be invalid and this might be the cause of inconsistent behaviour since you dont have any pullups or pulldown for VS pins
https://www.xilinx.com/support/documentation/user_guides/ug332.pdf
Visitor ebi1359
can I solve this problem without changing in my hardware and change the board?
check page 219 from the following link where it states that VS pins have weak pull-ups but it is recommended to have external resistors.
Variant select pins are dual purpose so there shouldn't be any activity from peripherls on this IO's if used until the configuration is complete if in case you are depending on the weak internal pull-ups.
However, it is suggested to follow the recommendations for the VS pins to have a correct configuration.
