Visitor jingchi
write_cfgmem SERIALx1 is this for master or slave mode?
in ug835 for command "write_cfgmem" in the arguments for interface, SERIALx1 is this for master mode or slave mode?
Scholar pratham
Re: write_cfgmem SERIALx1 is this for master or slave mode?
@jingchi Only the direction of the configuration clock gets change for slave mode hence the file generated would be same be it master or slave mode.
-Pratham
Scholar pratham
-Pratham
