xilinx FPGA Spartan-6
Hi all,
If I was loading .BIT file through JTAG into spartan-6, where this Bit file will be loaded or stored in Xilinx FPGA spartan-6. Example: Like Intel will load files in configuration flash memory.
Scholar dpaul24
Re: xilinx FPGA General
@sivakumarreddy50,
I think Xilinx also has an internal configuration memory.
FPGA enthusiast!
All PMs will be ignored
You can load the Spartan 6 through JTAG and it will configure the FPGA.  This is volatile.  Turn off the power and the programming goes away.  You can put a non-volatile memory (flash) on the poard and program it with a file and the FPGA will boot from the flash on power up.  You need to use ISE PROMGEN to turn the bitfile into a format suitable for the flash.
I'm asking where those files will reside in FPGA.
Scholar u4223374
As with any of the volatile FPGAs, the files are stored in the SRAM associated with the individual LUTs.
