Data-Width Conversion in FIFO Generator simulink and dspgen
Hello all,
I am using Matlab simulink and Xilinx sysgen. In this I would like to impleament a FIFO with input port data type depth and width of 2048 X 32 and output port data type 1024 X 64. Basically looking a similar module like this https://www.xilinx.com/support/documentation/application_notes/xapp261.pdf .  or how to implement / configure  Data-Width Conversion on a FIFO for a virtex 5 chip.
indrajit
Re: Data-Width Conversion in FIFO Generator simulink and dspgen
Hi @indrajitbarve ,
The FIFO block in the Sysgen doesnot provide the facility to use data width conversion on the FIFO I/O ports.
A way would be to use custom design FIFO in HDL and import that into the Sysgen.
Thanks, for your reply.
