Observer dkartis2
Digital Down Converter 1.0 on Virtex-6
I have an old ISE project that uses the Digital Down Converter 1.0 IP core. I need to convert to be used in ISE 14.4 but the DDC in that version looks to only support LTE and CDMA spectrums. Is there a way to get the Digital Down Converter 1.0 IP core to work with Virtex-6, even if it is not able to be optimized?
Thank you
Tags (4)
Re: Digital Down Converter 1.0 on Virtex-6
You can use the v1.1 core present in the latest version ISE14.7
It supports all the features supported in v1.0.
Satish
Observer dkartis2
Thank you for the reply, but what is currently in the IP core library is the DUC/DDC Complier which only supports specific wireless standards. The Digital Down Converter was a core generated in ISE 9.2 and was able to be used with a range of frequencies, I need something that's not specific to LTE and CDMA. Is my only option to digitally mix my signals and use a BPF?
Thanks again.
