Visitor keemz
Error Occurring during Netlist Generation
Hi everybody,
I am having trouble generating the Netlils from my sytem generator file, I am using Windows XP 32bit, and a 10.1 ISE.
The following error comes out when I try to generate the Netlist:
standard exception: XNetlistEngine:
An exception was raised:
com.xilinx.sysgen.netlist.NetlistInternal: couldn't run c:/xilinx/10.1/ise/bin/nt/coregen.exe: 1 at D:\svn_Karim\hw\measure\analysis\SimulChannel\netlist\sysgen\masterScript40471.pl line 515
Reported by:
Unspecified
Please note that there are no spaces or special characters in either of the paths.
I appreciate your help,
Cheers,
Karim
Re: Error Occurring during Netlist Generation
If you search the Xilinx Answers Database you will find numerous possiblie issues that relate to this error.
You have already removed spaces from the path, but you should also try to keep the target path as short as possible.  Sometimes long paths cause failures  You might want to try something like this.
C:\netlist
Also keep in mind that the names of the sub-modules also affects the path, so keep you sub-module names short as well in your SysGen MDL file.
Chris
Video Design Hub | Embedded SW Support
Visitor keemz
Dear Chris,
From the Xilinx database, I figured that the problem is that the compiler runs out of memory, when I tried to decrease the number of coefficients however, it seemed to work fine. Any idea what could be a solution for this?
karim
