Observer eldrick
FIR Compiler fails place_design
Currently trying to implement 16 512-tap Decimate by 4 FIR filters in Vivado for a ZU9EG device.
Running Vivado 2018.2 on Ubuntu.
Running into errors during place_design without any real explanation. The log shows:
Phase 2.1 Floorplanning
Abnormal program termination (11)
Please check '/home/[user]/Xilinx/Projects/[proj]/[proj].runs/impl_1/hs_err_pid1027.log' for details
hs_err_pid1027.log shows:
# An unexpected error has occurred (11)
Stack:
/lib/x86_64-linux-gnu/libc.so.6(+0x354b0) [0x7f9ddfec54b0]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFVPPlacer::~HAPLFVPPlacer()+0x290) [0x7f9db485e5f0]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::doVPPlacer(HAPLFVPPlacerParams const&, int&)+0x26e) [0x7f9db5225b9e]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::doVPPlacer(HAPLFVPPlacerParams const&)+0x23) [0x7f9db52378b3]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::doAltWeightsHMPlacerIterations(int, bool&, HAPLFTDMUtils::partitionWeights const&)+0x937) [0x7f9db5235e57]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::doHMPlacerIterations(int, bool&)+0x120) [0x7f9db5237170]
/home/[user]/Xilinx/Vivado/2019.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::doFloorplanning()+0x242) [0x7f9db52390e2]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::runMain1(bool&, bool&, bool, bool)+0x174) [0x7f9db52392f4]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_place.so(HAPLFQPILRPlacer::run(bool, bool, bool, bool, bool)+0x33) [0x7f9db523a463]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::doQPILRPlacement(unsigned int const&, bool, bool)+0x760) [0x7f9dba10a100]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::doGlobalPlacement(bool, bool)+0x655) [0x7f9dba10b725]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::doPlacement(bool, bool, unsigned int)+0xe4) [0x7f9dba10c0f4]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_implflow.so(HAPLFFastPlace3::place(HAPLPlaceApi&, HFLFloorplan&, HAPLFFastFlowParam const&, HDPLTask&, HAPLFMigPblockInfo const*)+0x7d5) [0x7f9dba10d235]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_implflow.so(HAPLFFastFlow3::place(HAPLFFastFlowParam const&, HAPLFMigPblockInfo const*)+0xd20) [0x7f9dba0d12f0]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_vivadotasks.so(+0x3e0710) [0x7f9da2eae710]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_vivadotasks.so(+0x3e4aca) [0x7f9da2eb2aca]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_common.so(+0x78e792) [0x7f9de1189792]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x334af) [0x7f9ddb5014af]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x76875) [0x7f9ddb544875]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x7e029) [0x7f9ddb54c029]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x76) [0x7f9ddb503156]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x1b26b4) [0x7f9dd5e226b4]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x34b38) [0x7f9ddb502b38]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0xad486) [0x7f9ddb57b486]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(+0x346c5) [0x7f9ddb5026c5]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_EvalEx+0x13) [0x7f9ddb5030a3]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_FSEvalFileEx+0x1da) [0x7f9ddb567c5a]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x1cf84d) [0x7f9dd5e3f84d]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x32) [0x7f9ddb5015e2]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x322) [0x7f9ddb503402]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x200e8f) [0x7f9dd5e70e8f]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commontasks.so(+0x20255e) [0x7f9dd5e7255e]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_commonmain.so(+0x7414) [0x7f9de07f7414]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d0) [0x7f9ddb56e210]
/home/[user]/Xilinx/Vivado/2018.2/lib/lnx64.o/librdi_common.so(+0x7d175b) [0x7f9de11cc75b]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba) [0x7f9ddfc7a6ba]
/lib/x87_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f9ddff9741d]
Any ideas on why this is happening? Resource utilization?
Observer eldrick
Re: FIR Compiler fails place_design
Resolved: You'll have to explicitly divide up your DSP slice columns into a custom configuration. In my case, dividing 128 slices into 4 columns of 32 worked. The synthesis tools, even under "Automatic" multi-column support mode, will not divide up your slices such that they will all fit consecutively.
Observer eldrick
Looks to be something related to # of FIR filters placed. Implemented successfully using only 8. Will try 12 and see where the boundary for success is.
Observer eldrick
I've upgraded to Vivado 2018.3 and got a more helpful report. The placer can't place down 5 of the filters, although I should be well under utilization. I suspect it has something to do with lack of consecutive DSP slices.
Observer eldrick
