Newbie doug1963
Half-band filter center tap
I'm designing a half-band decimate by 2 filter using the FIR compiler.  The filter operates with 16 clock cycles per output sample.  The filter has 63 taps so consequently there are 16 unique coefficients when taking into account symmetry and zero coefficients.  The center coefficient of any halfband filter is equal to 0.5 and should not require the use of a DSP slice as this is nothing by a data shift.  When I put the information into the FIR compiler it indicates that 2 DSP slices are required.  I think it should only require 1 slice.  It seems that the FIR compiler does not exploit the trivial center tap.  Is this the case?
-Doug
