How to generate a FFT without AXI interface, just for the PL usage, on ZCu102?
I want to use a FFT module, in the PL. So just as before we were able to generate it with Core Generator for Virtex 5 falimy, for example. I don't want a FFT IP core 9.1, with AXI interface, but the one with normal inputs (In_real, In_imag, etc). I am using a ZCU102 board.
Cristi
Re: How to generate a FFT without AXI interface, just for the PL usage, on ZCu102?
All the IPs are based on the AXI interface. This allows easy interfacing between different IPs.
You can not use the FFT IP without AXI interface now.
Scholar drjohnsmith
If i remember, these use the streaming AXI interface,
If you turn of the flow control in the IP, I think its called real time, then basically you just have data with an enable / valid signal.
which I think is as per before, ,,
Sorry, but maybe i am missing something. I can't find the settings you mentioned (i.e., 'to turn off the flow control in the IP'.
Can you please be more specific?
Thank you
Scholar drjohnsmith
If I remember....
on the implimentation tab of the fft, ( or something similarly named )
   you can select betwene real time and none real time throttle control ( or something similar named )
Throtle contoled , is the AXI port Valid / ready flags , that contorl the flow of bursty data through the core,
       You dont want that, your data is always there and cna always be taken at the end,
         so no need for real time control, just stream it in .
There is an open source FFT generator you might consider as well.  It doesn't have nearly all the bells and whistles of LogiCore's IP, you you might find that's what you are looking for.
Dan
