How to use FFT or any other AXI based IP without a processor ?
Accepted Solution Solved
Accepted Solution
Hello, I have initialised BRAM with audio signal, Now i want to take FFT of this signal using FFT ip core present in vivado. But i also dont want to use to processor to read data from BRAM and feed to the FFT ip core. What are the other possible ways i can achieve this.
Thanks in anticipation.
Re: How to use FFT or any other AXI based IP without a processor ?
@abhinav6 you can probably use this module to interface bram to FFT ip: https://www.xilinx.com/products/intellectual-property/axis_accelerator_adapter.html
All Replies
@abhinav6  What are the other possible ways i can achieve this.
You can write some HDL code or use HLS to send the data through the FFT core.
Best,
Herbert
[ Edited ]
You can use AXI stream and AXI DMA
Avi Chami MSc
FPGA Site
