Newbie daisywmc
How to used dpd_v4_0_dbg\vhdl\create_wrapper.pl to creat dpd_debug_wrapper.vhd in DPD V4.0
 How to used dpd_v4_0_dbg\vhdl\create_wrapper.pl to creat dpd_debug_wrapper.vhd in DPD V4.0?
what I should do before runing create_wrapper.pl and copy it to which file directories?
How to Use create_wrapper.pl to generate debug interfacewrapper vhdl file?
Re: How to used dpd_v4_0_dbg\vhdl\create_wrapper.pl to creat dpd_debug_wrapper.vhd in DPD V4.0
The DPD debug interface should be clearly documented in the Data Sheet for the DPD.
If you can not find this information, then you should open a case with the Xilinx Technical Support
Chris
Video Design Hub | Embedded SW Support
Visitor fallenleaf
Hi, I'm working on DPD IP recently too, and I'm a little confused about how to begin it, the core code is simple, should I insert MicroBlaze in my project? and should I use it when sampling signals on board and never do simulation?
do you use a evaluation version for DPD IP core?
Microblaze has been intergated into DPD. I do not think you can see the source code if you use DPD core in the CoreGen. It is provided in a NGC format.
create_wrapper.pl is used to install DPD debug interface on custom board. You do not need to use it if you just want to use the core only.
