Participant brechat
Inferring URAM with FIR Compiler
I have a project with a lot of FIR filters running on a Kintex Ultrascale (I use FIR compiler of Sysgen). I'm upgrading the design to an Ultrascale+ architecture but I'm running out of blocks RAM and the UltraRAM is unused. Is there any way to balance the use of BRAM/URAM?
Thank you!
回复: Inferring URAM with FIR Compiler
without using FIR Compiler, you can use URAM in building your own FIR filter.
In the FIR Compiler GUI, you can set the "Memory Options" to distributed ram.
Participant brechat
Hi @nathanx,
Thanks for your reply.
I did what you proposed but I didn't see any change. I've changed FIR implementation to Distributed RAM
But on the report utilisation I've always 0 utilization for UltraRAM
Do you have any ideas?
If you change FIR implementation to Distributed RAM, then it will definitely use zero URAM.
BTW, I don't think FIR GUI providing the user the option to use URAM, the FIR implementations just gives two options, one is block(block ram), the other is distributed(distributed ram).
Participant brechat
Hi @nathanx,
I'm a little bit confused with your two answers.
From your last message I understand that it is not possible to use Ultra RAM using FIR Compiler. Is that right? In that case, is it any way (maybe without using FIR Compiler) to implement a FIR filter using Ultra RAM?
Thanks for you support
Your assertion is true. FIR Compiler does not support URAM. Typically your tap size wouldn't require more that a few K coefficients which would fit into BRAM better than URAM.
