Visitor momran
LDPC Decoder Output behavior when using include_parity_op
I am simulating LDPC decoder IP on virtex ultrascale+ board and I am sending an input block of 280 words, and using paramters of N= 1120, K=840. What should be the expected output when using CTRL bit[16] which is include_parity_op = 1?
Because I am getting a behavior where m_axis_dout_tvalid stays high and m_axis_dout_tlast doesn't go high indicating last transaction of the block.
回复: LDPC Decoder Output behavior when using include_parity_op
M_axis_data_tready is an input, can you assert it to high for more time, it's probably due to that data is not completely output from the core.
