Port names moving from LogicCore FFT IP 7.1 to 9.1 and Test bench for 7.1
Our project uses LogicCore FFT IP module and we are upgrading from version 7.1 on Virtex6 platform to version 9.1 on Zynq platform.
I am trying to make sense of version 7.1 to 9.1 port mapping - cycle accurate - since the module is interfaced to memories on both read and write side and does that in bursts - so signals getting asserted or de-asserted one cycle too early or late leads to errors (that I am seeing - erroneous values).
It will be very kind if someone can help with two things -
1. What to connect the following new signals to -
s_axis_config_tvalid
s_axis_config_tready
s_axis_data_tlast
m_axis_data_tuser
 m_axis_data_tready
Also, How should I connect my logic that used to check for the following signals in previous version -
edone
done
dv
start
2. I also saw when I instantiate IP 9.1 a VHDL testbench is generated. The same is NOT done for IP version 7.1. I wish to use as close/similar a TB as possible for both IPs to draw comparison - but again I am stuck with the Q1 above.
It will be very kind if someone can tell me if there is any auto generated TB with 7.1 like 9.1 and where it is - or if there is a process to do it.
Thanks and sincerely
Bhawandeep SIngh
Re: Port names moving from LogicCore FFT IP 7.1 to 9.1 and Test bench for 7.1
FFT 7.1 is designed without using AXI protocol, whereas FFT 9.1 with AXI.
There is no automatic method to convert the FFT 7.1 to FFT 9.1.
Lastly, it is recommended to redesign the system for FFT 9.1 instead of adding blocks to FFT 7.1 design to connect with FFT 9.1.
