Newbie ucotecnico
Problems with the configuration of a ROM in System Generator 10.1
Hi! I'm having some problems with the configuration of a ROM in the System Generator 10.1.
I would like to implemente a ROM in order to save the program for a Picoblaze, but I'm not sure about the parameters and how to specify the program to store in the ROM.
Can someone explain me the process?
Thank you
Re: Problems with the configuration of a ROM in System Generator 10.1
The steps are outlined in the "PicoBlaze Microcontroller" section of the System Generator for DSP Reference Guide.
  1. Write a PicoBlaze program. Save the program with a .psm file extension.
  2. Run the assembler from the MATLAB command prompt as follows:
      For PicoBlaze 3:
      xlpb_as –p <your_design>.psm
      For PicoBlaze 2:
      xlpb_as –p <your_design>.psm -v 2
      The above command generates a M-file, fill_<your_design>_program_store.m, for initializing the content of the ROM block.
  3. Set the "Initial value vector" field of the ROM block to fill_<your_design>_program_store.
Problems with the configuration of a ROM in System Generator 12.4
Dear Support!
  I'm using MATLAB 7.11.0 and SysGen from Xilinx 12.4 ISE on Win7 x64.
  When I start 'xlpb_as' with the correct parameters I've got the error message:
??? Error using ==> xlpb_as at 33
error: couldn't run wrapkcpsm3.bat
And I could not find any batch file like this in the filesystem.
The 'kcpsm3.exe' exists in the 'Xilinx\12.4\ISE_DS\ISE\sysgen\bin\nt64'.
My questions are now:
How can I generate the .m file to configure the ROM?
How can I solve the issue of missing wrapper?
Thanks a lot,
Zoltan Pataki
Re: Problems with the configuration of a ROM in System Generator 12.4
The results of my additional inspections:
  The error message is misleading. Due to full path length limitation I've made a temporary directory in the network for compilation, that was the reason why I could not find the wrapper batch in the filesystem. It is created during compilation, in a new folder: 'projectname'_psm_results. But when I'm trying to start it directly I've got:
  This version of C:\Xilinx\12.4\ISE_DS\ISE\sysgen\bin\nt64\kcpsm3.exe is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need a x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.
  And as I see it is a known issue:
KCPSM3 for windows 7 64-bit?
  Could anybody send me a link for the for the Win7 x64 compatible kcpsm3.exe?
Thanks a lot.
Tags (3)
Newbie azed10
@pataki.zoltan wrote:
Dear Support!
Thanks a lot,
Zoltan Pataki
Hi! I have the same problem, When i run xlpb_as on my .psm file Matlab creates the folder 'projectname'_psm_results but it can't access it. I added it to the path but then i got the following message:
C:/KANE_Workspace/WorkPlace/PicoBlaze_Test/pico_code.psmerror: couldn't discard old copy of
C:/KANE_Workspace/WorkPlace/PicoBlaze_Test/pico_code_psm_results. Perhaps ta mere NT thinks it's in use?
I tried changing the folders properties to be able to read and write in it but it would not work even though I had administrator's priviledges. Plus the folder is automatically deletes when I shut down Matlab!
I am using Matlab R2011a and System generator 14.1
Thank you
