Observer panospet
Resample in Sysgen...
Any ideas of how can I implement the "resample" MATLAB code in a xilinx sygen design?
thank you in advance.
panospet
Tags (4)
Re: Resample in Sysgen...
Depending on exactly what you're trying to do, you could use a combination of FIR, CIC, upsample, and/or downsample blocks.
www.xilinx.com
If the rate change is fixed, you can use FIR comipler to generate a polyphase filter: set filter type to "interpolation" or "decimation", then set rate change type to "fixed_fractional". you can then set value for p and q.
Cheers,
Jim
Observer panospet
Thanks a lot.
Unfortunately I'm running an older version of sysgen, and I have up to FIR compiler 5.0.
Is there a similar way with this?
Can I also use FDA tool?
Observer panospet
Sorry, I meant up to FIR compiler 4.0
Observer panospet
And how do I choose my coefficient vector?
Sorry I don't have old versions installed any more to confirm. Can you attach a screenshot of what the FIR Compiler 4.0 GUI looks like?
Cheers,
Jim
You use FDATools to design your filter (choose coefficient vector) and use FIR Compiler to implement the filter in FPGA.
Cheers,
Jim
Observer panospet
I will put [1] as my coefficient vector because I dont want any changes to my signal, I only want to resample it.
Do I need to change my clock to do this? That makes my odjective much more complicated.
Ps. I attach my design, if it helps. The audio signal is imported in the design using wavread command in matlab, and then the "from workspace" block. My goal is to implement the "pitch shifting" effect, as the matlab code does.
Observer panospet
Also, I want to do a 6/7 resampling to my signal.
When I set my interpolation rate value to "6" and decimation to "7", I get this error:
In your case, you need to set filter type to "Decimation"
Interpolation = resample rate > 1
Decimation = resample rate < 1
Cheers,
Jim
Observer panospet
I also tried the "decimation" filter type, I get this error. (different than the previous).
Do I have to do something with my clock?
Observer panospet
anyone?
