Observer jmorenoz
Sysgen 2018.2 and Matlab R2018A starting errors in Linux
Please I need help with new versions of Vivado Suite System Edition 2018.2 and Matlab 2018a, it's not possible to exec matlab throught sysgen and the MATLAB root seems correct, also reports an awk error.
I have reinstalled from root and try execute with root also with the same results.
Neither I have found de Sysgen configurator for setting the Matlab version like in previous version.
I expect you can help me, thanks in advance.
$ which matlab
/usr/local/MATLAB/R2018a/bin/matlab
Output:
$ sysgen
awk: symbol lookup error: awk: undefined symbol: mpfr_z_sub
Internal error 2: Could not determine the path of the
                  MATLAB root directory.
                  original command path = /usr/local/MATLAB/R2018a/bin/matlab
                  current  command path = /usr/local/MATLAB/R2018a/bin/matlab
                  Please contact:
                      MathWorks Technical Support
                  for further assistance.
PATHs list:
/opt/sw/xilinx/Model_Composer/2018.2/bin
/opt/sw/xilinx/DocNav
/opt/sw/xilinx/SDK/2018.2/bin
/opt/sw/xilinx/SDK/2018.2/gnu/microblaze/lin/bin
/opt/sw/xilinx/SDK/2018.2/gnu/arm/lin/bin
/opt/sw/xilinx/SDK/2018.2/gnu/microblaze/linux_toolchain/lin64_le/bin
/opt/sw/xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin
/opt/sw/xilinx/SDK/2018.2/gnu/aarch32/lin/gcc-arm-none-eabi/bin
/opt/sw/xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/bin
/opt/sw/xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-none/bin
/opt/sw/xilinx/SDK/2018.2/gnu/armr5/lin/gcc-arm-none-eabi/bin
/opt/sw/xilinx/SDK/2018.2/tps/lnx64/cmake-3.3.2/bin
/opt/sw/xilinx/Vivado/2018.2/bin
/home/josan/bin
/opt/sw/bin
/bin
/usr/bin
/usr/local/bin
/sbin
/usr/sbin
$ echo $LD_LIBRARY_PATH
/usr/local/lib64:/usr/local/lib
$ uname -a
Linux m4z 4.9.0-8-amd64 #1 SMP Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64 GNU/Linux
-- j054n
Re: Sysgen 2018.2 and Matlab R2018A starting errors in Linux
Hi ,
Can you please comment what is the Linux OS version that you are using. Please see the below OS supportted by Vivado 2018.2 and MATLAB 2018a . It supports only Red Hat Linux 64 and Red Hat Linux
Please refer to Vivado release notes UG973 to know more about the supported OS and 3rd party tools by Vivado.
Vivek
Observer jmorenoz
Certainly my current OS doesn't appear in this table, but I have just tested in a Centos 7 wit the same result
$ uname -a
Linux elab 3.10.0-862.14.4.el7.x86_64 #1 SMP Wed Sep 26 15:12:11 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
$ rpm -q centos-release
centos-release-7-5.1804.4.el7.centos.x86_64
In this machine I can use Sysgen 2017.4 with Matlab 2017a, but with 2018 versions in a similar installation gives the same error
-- j054n
I see another user on forum faced a similar problem, given in the below link. He has solved it by installing KDE. Please see the below link
https://forums.xilinx.com/t5/DSP-IP-and-Tools/Error-using-System-Generator/td-p/900420
Please try this and check.
Vivek
Newbie abansod88
I faced same issue while running this setup on debian.
I located the issue on matlab script line: 380
newdir=`echo "$filename" | awk '
                        { tail = $0
                          np = index (tail, "/")
                          while ( np != 0 ) {
                             tail = substr (tail, np + 1, length (tail) - np)
                             if (tail == "" ) break
                          head = substr ($0, 1, length ($0) - length (tail))
                          if ( tail == "." || tail == "..")
                             print $0
                          else
                             print head
I fixed it by giving the correct value to this variable as follows:
newdir="<your dir path>/MATLAB/R2018a/bin"
Afterwards sysgen runs properly!
Hope it helps.
Cheers,
