Visitor darking2539
Sysgen IPCORE
Hi. Has anyone ever worked with Xilinx system generator and IP Integrator I want to design add bit shown in below photo
I want to number plus a number( eg. 5+5=10) and show result by xil_printf using write C code by using SDK.
Thankyou
Re: Sysgen IPCORE
You can export the SysGen project as Vivado project using "System generator token". Open the token and select the device (and testbench option) and press generate. The vivado project will be saved at location "<project directory>\netlist\ip_catalog".
After that you can use the IP with SDK to show the results.
