Visitor enisosousse
System Generator:Error when starting code generation
I am trying to generate VHDL code for a Simulink model using System Generator. Once it starts the process, a message box
is showing the following message:
"??? Error using ==> xlSysgenGUI('save');
Error using ==> set_param
Xilinx System Generator block (mask) does not have a parameter named 'clock_wrapper'.
??? Error while evaluating uicontrol Callback".
I tried to solve the problem but this error is still coming out. I really need to get this code.
Could you please tell me what can I do to overcome this issue?
Kind regards
Re: System Generator:Error when starting code generation
The System Generator block may get into a bad state.  Try removing the System Generator block from your design and then inserting a new one.
