Visitor inventor_1
System generator for DSP- Float point mult - use AXI4-stream interface
Hi!
1.how can I use the signals of the AXI-stream interface (for example _tvalid) on the float point mult block in the model?
2.how can i manage the amount of dsp slice used in a float point mult block?
Re: System generator for DSP- Float point mult - use AXI4-stream interface
1)The mult block under the math tab in sysgen don't have a AXI Stream Interface. You can add a couple AXI FIFO blocks to you design and then implement the AXI Stream Interface.
2) To control the number of XtremeDSP slice ( DSP 48) that you are using, just disable the option: Use embedded multipliers, under the Implementation tab in the Mult control window, this option is set by default and specifies that if possible, use the DSP48 blocks in the FPGA.
I hope that this information was useful to you.
