Unable to see System Generator Clock from Blackbox
Hello,one interesting question i came across by one of my friends Luis Manuel that , how can we see the clock of system generator?
I have written one verilog code, in which:
Initialization of d as d=0, then doing d=~d at every positive edge of clk.
clk_out=clk has been assigned.
module firs(clk,ce,clk_out,d);
input clk,ce;
output clk_out;
output reg d;
assign clk_out=clk;
initial
begin
d=0;
end
always @(posedge clk)
begin
d=~d;
end
endmodule
After running the program, in Wavescope i get is,
Clk_out is always remaining 0.
So always@(posedge clk) whatever operation was there =>Invert d that took place, but we are not able to see the clk.
Vihang Naik
Voyager
Voyager
Re: Unable to see System Generator Clock from Blackbox
Why you want a clock of the black box ?
If you want use a clock of model use "Clock Probe" on "Xilinx Blockset -> Tools"
secureasm
Hello,thanks for your reply.
Yes,I totally agree that Clock Probe gives us clock, .
But without using it as i have written the program, logically it should work,why it is remaining 0 all the time.
In the same program,one operation is done with respect to clk,so why we are not able to see the same?
Vihang Naik
you are trying to see two signals from the Simulink domain (after gateway out) in Wavescope that is used to plot signals from System Generator, are you sure this is allowed?
Scholar joelby
I'm not 100% sure I understand your problem because it involves System Generator, but I imagine it is because you're trying to sample clk_out using clk as the sampling clock. If you sample a signal using that signal as a trigger, the value will be constant and either zero or one depending on the clock edge you're sampling on (disregarding setup/hold times, etc.)
As an analogy, imagine trying to take a photograph of a camera in a mirror. From viewing a series of photos, you might think that the camera's shutter is always open, but this is just because of your sampling method. You'd need to sample the clock signal at both edges of the clock (or somehow take a photograph of the camera when the shutter is closed), or use a different, faster clock.
Hello edelcas,
As far as i know it allows,otherwise if it did not allow then we would not have been able to see the second signal in wavescope(see screenshot above).
Vihang Naik
