Visitor nwkrix
Vivado system generator always loading Configurator even though it says configured
Please how can this issue be addressed? I have tried loading the Vivado System Generator as admin. All to no avail. It just kept opening the already configured configurator over and over again.
Re: Vivado system generator always loading Configurator even though it says configured
Are you able to open the SysGen after adding the matlab in configurator.
Note that, both SysGen and SysGen-configurator has same icons.
Can you go to below location and try to run both the shortcuts there; and see if any one of the two shortcuts are working fine.
Replace <username> with your username and change the vivado version in the below path.
C:\Users\<username>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Xilinx Design Tools\Vivado 2018.3\System Generator
