Visitor alexshel44
Xilinx xfft 8.0 Cmodel Compilation Error
I am currently trying to compile the example code for the bit accurate cmodel for the Xilinx xfft 8.0 core ip.
The is pointing to the .lib file but when I build the project I get the below errors.
What could be causing this?
Alex
Re: Xilinx xfft 8.0 Cmodel Compilation Error
Have you tried searching for these types of errors? They are discussed a lot on these forums. :)
www.xilinx.com
Visitor alexshel44
I found this thread http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/FFT-C-model-C-simulation-fails-to-compile/m-p/393587#M3697 that solved the problem. I was using a 32bit compiler for the 64bit version.
But now I am gettting a different error:
error LNK2019: unresolved external symbol __imp___CrtDbgReportW referenced in function "public: char const & __thiscall std::_String_const_iterator<class std::_String_val<struct std::_Simple_types<char> > >::operator*(void)const " (??D?$_String_const_iterator@V?$_String_val@U?$_Simple_types@D@std@@@std@@@std@@QBEABDXZ)    C:\Users\Lab 538A\Desktop\xfft_v8_0_bitacc_cmodel_nt\FFT_CModel32bit\FFT_CModel32bit\run_bitacc_cmodel.obj    FFT_CModel32bit
Alex
Visitor alexshel44
Solved:
For whatever reason it seems that It has to be compiled in Release mode not debug.
Visitor alexshel44
This allowed the program to compile but, now it gets a runtime error.
Runtime Error!
R6034
An application has made an attempt to laod the C runtime library incorrectly
-Alex
Check below link
http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/FFT-C-model-C-simulation-fails-to-compile/td-p/390775
Satish
Visitor alexshel44
Thanks for the reply,
The solution in that post says we need to be in Release mode and that embed manifest needs to be set to yes. I have verified that these settings are correct and the problem still persists.
-Alex
Visitor alexshel44
I also get an error if MSVCp90.dll or stlport.5.1.dll are not in the same directory as the executable.
Hello Alex,
Oh sorry, I think this thread will help:
http://forums.xilinx.com/t5/DSP-Tools/Xilinx-FFT-C-Model-and-Windows-7-64-bit-not-working/td-p/282252
www.xilinx.com
