Observer rica.soles
Hi!
I'm workin in vivado and i have a problem with IP  DDS V.6. I do the conexion with clocking wizard to DDS IP. In the simulation is fine, i can see sine wave but i program the board nexys video, in the port (PMOD, JB and JC) when i check this port with a oscilloscope i don't see nothing only noise. I supose which i need see the signal each port.
In the next picture I do simulation. I think which in each port JB and JC i need see the signal as in simulation but i don't see nothing.
any suggestions.
Thanks! regards.
While I am not familiar with the Nexis Video board, the description leads me to believe that the PMODs are not connected to a Digital to Analog converter.  If you have a 3.3V logic signal changing 100 million times a second going through a PMOD connector, the signal you are seeing on the scope is to be expected. Remember, you will not see a sine wave, you will see one of 16 digital signals on your scope.  If you look at the signal with a faster time base, say 20nS/division, you should see a typical digital signal.  It may be somewhat distorted, since PMOD connectors are not very good for high speed signal integrity.
If you want to see a sine wave, you need a digital-to-analog converter and connect your data bus to it.
Can you post a picture of what you see on the scope?  Are your PMOD connectors digital outputs?   What voltage level?  how fast is your clock running?
Observer rica.soles
Hi!
Thanks for answer.
This is my picture of oscilloscope.
In my program the PMOD i configure from of Schematic. Look the picture. In this part i configure the port for PMOD JB and JC.
This is my net list.
Nexys video works with a clock the 100Mhz. I work with that clock for DDs.
Observer rica.soles
May be i dont explain well ... you have reason. I need to see each port . For example if my dds have 16 exits. I need to see any out in the oscilloscope, before connect any CAD. This for know if my DDS is working. But when i connect the oscilloscope in the PMOD a dont see nathing.
Furthermore, the pmod dont work for signals this type. You have reason.
Thanks for you help amd time.
Regards.
Observer rica.soles
But still I can not solve the problem. I already change ports and I still do not see anything. I adjust the oscilloscope to see some signal like those in the simulation and nothing.
From your siimulation, I think you are expecting a sine wave of 1MHz from your DDS.  What is the time base of your scope set to?  From your screenshot, it looks like it might be 500mS/division, but I don't know your scope.  This is way too long.  The Most significant Bit (MSB) of your DDS output should be a square wave of the frequency you are expecting.  Set your scope to something like 1uS/division and look at the MSB.  You could also put an ILA on the output of your DDS if you want to see what it is doing.
Observer rica.soles
"The Most significant Bit (MSB) of your DDS output should be a square wave of the frequency you are expecting. "
Its correct, i do connect with the most significant bit and see the signal. In my case is the pin sen[15], and the DDS give me the frequency 1Mhz approx.
On the other hand, that signal not see well because the pin of nexys video not have a coupling system.
thank for your help and time.
Observer rica.soles
what is ILA?
The Integrated Logic Analyzer is a core that let's you monitor signals in the FPGA.  https://www.xilinx.com/support/documentation/ip_documentation/ila/v6_2/pg172-ila.pdf
Observer motagiyash
Hey can you give us your testbench and guide lines like what you have done.
Observer rica.soles
Thanks for you help.
Regards.
Observer rica.soles
Hi!!!
What is the test breanch, is the same to simulation, you need images?
And other hand, you need the program in VHDL? I dont understan your question..."guide lines like what you have done." What do you meen?
Regards.
Observer motagiyash
Hello
Plz help me out. I think i am missing somthing completly.
I just want to create the sine wave of 90 mhz.
i use sin cos lut mode.
i connected the clock and the constant.
whats the deal wit phase tdata .
i created a tb for wrapper.
But i get the wrong waveform.
entity tb is
--  Port ( );
end tb;
architecture Behavioral of tb is
component design_1_wrapper is
  port (
    m_axis_data_tdata : out STD_LOGIC_VECTOR ( 15 downto 0 );
    m_axis_data_tvalid : out STD_LOGIC;
    s_axis_phase_tdata : in STD_LOGIC_VECTOR ( 15 downto 0 )
  end component;
 signal tdata       : STD_LOGIC_VECTOR ( 15 downto 0 );
 signal tvalid      : STD_LOGIC;
 signal phase_tdata : STD_LOGIC_VECTOR ( 15 downto 0 ) := x"0000";
begin
DUT : design_1_wrapper port map (m_axis_data_tdata=>tdata,m_axis_data_tvalid=>tvalid,s_axis_phase_tdata=>phase_tdata);
process
begin
phase_tdata <= phase_tdata + 1;
end process;
end Behavioral;
Scholar ronnywebers
your waveform looks strange, because you must tell Vivado's simulator/waveform viewer to interprete the values as signed or unsigned.
right-click on the 'strange' sine-waveform, and select the correct data-format
right click on the waveform-name in waveform viewer.
Next, click on radix and set it as 'signed decimal'.
It will show the expected waveform...
