Visitor malgassim
error in M block ?
I wrote this code inside the M Blcok (one of Xilinx blockstes in Simulink):
function z= discreatcorr(x,y)
t=zeros(12288,1);
i=zeros(1,12288);
i(1,4096:8191)=x(1:4096,1); %output of the image filter
t(4096:8191,1)=y(1:4096,1); %output of the tamplate filter
for n=1:8191
k=zeros(12288,1);
k(n:n+4095,1)=t(4096:8191,1);
z(n,1)=i*k;
end
end
Its telling me:
Error("discreatcorr.m"): output z is not assigned through all possible paths. A misspelling or a switch statement without otherwise statement may cause this error.
Error occurred during "Rate and Type Error Checking".
Any Ideas??
(model is attached)
Tags (2)
Re: error in M block ?
I'm not exactly sure what the problem is on this, but it seems that you are trying to do array operations on vector data.
Remember that you get one sample at a time through a gate way, not a whole array.  If you want to do an array operation, then you need to buffer up the data and then operate on it.
In your example, you have x and y comming into the m-code block, but you try to do an array assignment to I and T.
What you might want to try doing is doing this through a loop that assignes one value at each "clock cycle".
It may even may more sense to build this circuit out of descrete blocks, rather than trying to infer it via m-code.
In system Generator, the support for m-code is pretty limited, and mostly targeted at control logic, rather than full circuit implemenations.  I recommend you review the m-code support section of the System Generator for DSP User Guide.
Chris
Video Design Hub | Embedded SW Support
