inout in black box
inout in black box
Hi everyone,
when I generate a black box, it seems that inout pin dosn't appear, how i can solve this problem.
thank you
Re: inout in black box
@mimo you may not have inout pins at an internal boundary. Your only option is to export 3 wires (out, enable, in) and connect that to an IO pin at the top level.
what means enable ?
In your HDL, rather than use a bidirectional data type, separately implement the three signals which will be used for the tri-state.
https://www.xilinx.com/support/answers/44151.html
Thanks and Regards
Balkrishan
@mimo to drive an inout wire, you need a driver with tri-state signal (or enable), output signal itself and an input signal. If the tri-state driver is disabled, you can receive the other side's signal, if it's enabled, you can transmit the output to the wire.
Thank you for the replies,
First I made a vhdl module to comunicate with an adc external chip using i2c (SDA bidirectional) and its work fine with the tri-state mode. when i want to import this vhdl file into a black box in system generator, i can't map the SDA in and out pins with the same LOC using HW cosim. how i can solve this problem ?
I would recommend you to integrate i2c and sysgen design in Vivado project . You can generate your sysgen design and in vivado project integrate i2c design and sysgen design
Thanks and Regards
Balkrishan
i have spartan 3e its supported by ISE
I think that is not supported by vivado
