Visitor deepanwita
output of lowpass filter
when i put a sound in the "from media file"block in sysgen , we can't get the output from lowpass filter.........please send me the process of taking sound through 'from media file'.
Visitor deepanwita
Re: output of lowpass filter
you may sent doccument in my mail. my mail id is deepanwitasar@gmail.com
Advisor eilert
Advisor
is the data output of the "from media file" block generating one value at a time or is ist a whole vector at once (which would be bad for sysgen).
Do you use the same sampling rate on all the blocks and as the simulink period in the "system Generator" block?
If the data rates don't match, there's no data to be processed.
Have a nice simulation
  Eilert
Visitor deepanwita
below i give my design ......i can't get the output......can you help me..you may send doccument in my mail.
Can you attach the .mdl file?
Cheers,
Jim
Visitor deepanwita
i attach my .mdl file............
Visitor deepanwita
i m working at  xilinx ise 12.3
You have way too many sampling rates in your model. The sampling rate for the input data file, SysGen blocks, and FIR filters are all different. You may have a good reason to do that, but I suggest you double check that and straighten out the sample rates first. You can click "Format->Sample Time Display->Annotations" to display sample rate, which may help you see sample time difference at various points.
Cheers,
Jim
Visitor deepanwita
how i eleminate the error...............i give the error report
It looks like an issue with the sample time on the "Spectrum Scope" block. Try change that to match the sample time of the input signal.
Cheers,
Jim
