xilinx system generator IDS14.7 and matlab R2016a
I want to know if the  DSP system generator on ISE14.7 (system edition) is compatible with matlabR2016a ?Itry to configure it but a obtain the message  :Matlab configuration error ,filed to open temporary file .?? is there a solution or Imust replace ISE14.7 with a vivado version , so i want to work with this configuation(ISE 14.7 and Matlab R2016a)
Re: xilinx system generator IDS14.7 and matlab R2016a
Hi @mirabelle275,
Which OS you are tergeting?
If Windows 7, then please check this AR#:
https://www.xilinx.com/support/answers/37022.html
Another reason for it might be if  you don't run as admin. Right-click the configurator and select 'Run as Administrator'.
Hope the provided information will be helpful.
Raj
