cross - correlation of two sine signals using xilinx blockset
I took a sin wave block and took the coefficients of them and made and reversal of those coefficients and used them in fir complier as coefficients and then connected the same sine wave block to fir complier and was not getting the output . it is always showing zero.
please help me
waiting for your reply
 mahadev
Re: cross - correlation of two sine signals using xilinx blockset
If you can attach your model, that'll be very helpful.
Cheers,
Jim
can u plz me in other prob where i need  to find the max value  and its index of the signal using xilinx blickset
You could do this with a counter and a simple comparator. You just compare the current value against the largest saved value and when you find a higher value you store it in a RAM along with its count. And just repeat until you finish traversing your data set.
Chris
Video Design Hub | Embedded SW Support
actually what is the prob is i am having some values which are not a number ie is nan so the comparator was showing the error bool type output port op gets inderminate value and also sending u the model as attachment and also u can see the models above one and below one it is getting input from DAFIR with a latency of 14 so forst 14 values are nan's.
and values of input  are
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
NaN
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
-0.0009
-0.0018
-0.0025
-0.003
-0.0032
-0.0032
-0.002
-0.0026
-0.0179
-0.0484
-0.0857
-0.125
-0.1575
-0.1782
-0.1817
-0.1642
-0.1243
-0.0623
0.0183
0.1113
0.2091
0.3044
0.3868
0.4482
0.4815
0.4815
0.4452
0.3724
0.2663
0.1326
-0.0213
-0.1835
-0.3417
-0.4839
-0.5991
-0.6775
-0.7116
-0.6971
-0.6331
-0.522
-0.3697
-0.1857
0.0171
0.2257
0.4267
0.604
0.7446
0.8377
0.8749
0.8528
0.7709
0.6338
0.45
0.2313
-0.0083
-0.2523
-0.4838
-0.6861
-0.8442
-0.9472
-0.9871
-0.9593
-0.8656
-0.7123
-0.5082
-0.2661
-0.0028
0.2648
0.5173
0.7382
0.9107
1.0227
1.0657
1.0367
0.9368
0.7717
0.5528
0.294
0.0122
-0.2724
-0.5404
-0.7724
-0.9537
-1.0717
-1.1164
-1.0858
-0.981
-0.8091
-0.5818
-0.3127
-0.0212
0.2728
0.5502
0.792
0.9808
1.1037
1.1511
1.121
1.0144
0.8385
0.6053
0.3298
0.0298
-0.2731
-0.5575
-0.8038
-0.9963
-1.1219
-1.1709
-1.14
-1.0324
-0.8542
-0.6178
-0.3391
-0.0372
0.2682
0.5555
0.8058
1.0023
1.1305
1.1825
1.154
1.0477
0.8699
0.6328
0.3525
0.0462
-0.2613
-0.536
-0.7579
-0.9179
-1.0077
-1.027
-0.9774
-0.8662
-0.7055
-0.508
-0.2895
-0.0654
0.1484
0.3409
0.4983
0.614
0.6816
0.7004
0.6729
0.6031
0.4984
0.3676
0.2223
0.072
-0.0734
-0.2043
-0.313
-0.3944
-0.4451
-0.4635
-0.4496
-0.408
-0.3435
-0.2613
-0.1677
-0.0698
0.0259
0.1122
0.1853
0.2406
0.2762
0.2919
0.2875
0.2653
0.2277
0.179
0.1225
0.0627
0.0037
-0.0498
-0.0953
-0.1317
-0.1558
-0.1679
-0.1691
-0.1594
-0.1403
-0.1151
-0.0852
-0.0537
-0.0225
0.0074
0.033
0.0538
0.0692
0.0784
0.0817
0.0808
0.0757
CODE FOR ALL MODELS ARE:
XLMAX4:
function [t_max, out2] = xlmax4(out1,max,t_max_i,clk)
%t_max=0;
% count=0;
if(out1 >= max)
%     count=count+1;
    t_max=clk;
    out2 = out1;
else
%     count=count+1;
    t_max = t_max_i;
    out2 = max;
end
XLMAX5:
function [t_max] = xlmax5(Lin1, clk, t_max_i)
%t_max=0;
% count=0;
if(Lin1 == 1)
%     count=count+1;
    t_max = clk;
else
%     count=count+1;
    t_max = t_max_i;
end
XLMAX6:
function [X_corr_o] = xlmax6(Lin1, X_corr_i,X_corr_d)
%t_max=0;
% count=0;
if(Lin1 == 1)
%     count=count+1;
    X_corr_o = X_corr_i;
else
%     count=count+1;
    X_corr_o = X_corr_d;
end
Hi Consisder using an assert block and if you are having Nan consider use of a register with an enable and make use of a valid signal
Mike
the DA filter does have a valid output. So use this with enabled register
Mike
