problems with HDL Co-Simulation!!!!
Hi:
everyone!
There is a blackbox in my SystemGenerator model,and I think I have done the right setting of the blackbox block ,cause if I chose ISE simulator as the simulation mode, the whole simulation  was OK. However,when I chose  ModelSim as the simulator, there will be some errors listed as follows:
An internal error occurred in the Xilinx Blockset Library.(reported by SystemGenerator)
 (imformation listed as follows in Transcript Window when ModelSim was compliling)
# Model Technology ModelSim SE vcom 6.3c Compiler 2007.09 Sep 11 2007
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package numeric_std
# -- Compiling package conv_pkg
# -- Compiling package body conv_pkg
# -- Loading package conv_pkg
# -- Compiling package clock_pkg
# ** Error: ofdm_txrx_mimo_coded_cosim.vhd(1410): Library unisim not found.
# ** Error: ofdm_txrx_mimo_coded_cosim.vhd(1411): (vcom-1136) Unknown identifier "unisim".
# ** Error: ofdm_txrx_mimo_coded_cosim.vhd(1416): VHDL Compiler exiting
# ** Error: f:/Modeltech_6.3c/win32/vcom failed.
# Executing ONERROR command at macro ./ofdm_txrx_mimo_coded_cosim_cw.tcl line 141
     The question is that why ModelSim would compile the VHDLmodules while my module included by blackbox is a verilog module? I mean the HDL file format in the directory is #.v not #.vhd, the ModelSim should do the verilog compiling .
     Version : ModelSim 6.3c ,Matlab 2008a ,ISE 10.1,SystemGenerator 10.1
      I had complied the library  unsim and xilinxcore to ModelSim, and it was OK when I did simulation using ModelSim in other project.
    Please help!!
Re: problems with HDL Co-Simulation!!!!
You probably don't have the unisim models mapped in ModelSim. First, check your modelsim.ini to see if the following mappings are defined properly under the library section.
[Library]
unisim = <somewhere>/unisim
unisims_ver = <somewhere>/unisims_ver
simprim = <somewhere>/simprim
simprims_ver = <somewhere>/simprims_ver
xilinxcorelib = <somewhere>/xilinxcorelib
xilinxcorelib_ver = <somewhere>/xilinxcorelib_ver
If not, you can use "compxlib" or "compxlibgui" provided by ISE to compile the unisim/simprim/xilinxcorelib libraries for ModelSim.
This answer record provides further details: http://www.xilinx.com/support/answers/15338.htm
Hi;
benchan, you  have helped twice, I just want to  say -Thank you!
 Following your instruction , I figured the problem out.
 But ,I still can't understand that why the ModelSim would need  "Library unisim",I didn't compile this library before ,cause I chose verilog as HDL,so I compiled unisim_ver instead. "Unisim" is VHDL's library ,right?
The System Generator BlackBox creates a wrapper in VHDL (regardless of the type of HDL that you import into the BlackBox) when doing HDL co-simulation with ModelSim. That's why you will see ofdm_txrx_mimo_coded_cosim.vhd in the ModelSim log. And it seems like ofdm_txrx_mimo_coded_cosim.vhd refers to unisim, so unisim VHDL library mapping is required.
Thank you again !  benchan.
 I think  Xilinx should hire you as an employee  !
