DNNDK for SDSoC dpucore_zu7 error
I tried to build dpucore_zu7 workspace of DNNDK for SDSoC( https://www.xilinx.com/member/forms/download/dnndk-eula-xef.html?filename=xlnx_dnndk_for_sdsoc.tar.gz )
I met the following error.
How can I fix the error?
/media/hokim/data/Xilinx/SDx/2018.3/bin/xsltproc  --output   --stringparam P_TEMPLATE "dpu_set_reset<0,DEFAULT_PARAM>"  --stringparam P_FUNCTION "dpu_set_reset"  --stringparam P_WRAPPER  "w0_dpu_set_reset"  --stringparam P_RES_ID 0  --stringparam P_PARAM_FILE ""  /media/hokim/data/Xilinx/SDx/2018.3/scripts/xsd/xdChangeFcnMapTemplate.xsl
warning: failed to load external entity "P_TEMPLATE"
cannot parse P_TEMPLATE
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling '/media/hokim/data/Xilinx/SDx/2018.3/bin/xsltproc  --output   --stringparam P_TEMPLATE "dpu_set_reset<0,DEFAULT_PARAM>"  --stringparam P_FUNCTION "dpu_set_reset"  --stringparam P_WRAPPER  "w0_dpu_set_reset"  --stringparam P_RES_ID 0  --stringparam P_PARAM_FILE ""  /media/hokim/data/Xilinx/SDx/2018.3/scripts/xsd/xdChangeFcnMapTemplate.xsl  '
dpucore_zu9 doesn't cause such error
Thanks in advance
Observer jorge_2015
Re: DNNDK for SDSoC dpucore_zu7 error
Observer jorge_2015
