Participant jorlamp
Deephi image get stuck in Starting Kernel for ZCU102
Hi!
I have a ZCU102 Revision 1.1 board and sometimes I am able to see Deephi Linaro Desktop and launch the example applications but other times I get stuck here:
Xilinx Zynq MP First Stage Boot Loader
Release 2017.1   Sep 23 2018  -  18:42:16
NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):47af34b
NOTICE:  BL31: Built : 02:46:52, Jun 19 2018
PMUFW:  v0.3
U-Boot 2017.01 (Jun 27 2017 - 17:02:57 +0800) Xilinx ZynqMP ZCU102 revB
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        xczu9eg
MMC:   sdhci@ff170000: 0 (SD)
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 using MAC address from ROM
eth0: ethernet@ff0e0000
switch to partitions #0, OK
mmc0 is current device
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading uEnv.txt
166 bytes read in 8 ms (19.5 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
reading system.dtb
36852 bytes read in 16 ms (2.2 MiB/s)
reading Image
9689096 bytes read in 693 ms (13.3 MiB/s)
## Flattened Device Tree blob at 04000000
   Booting using the fdt blob at 0x4000000
   Loading Device Tree to 000000000fff4000, end 000000000ffffff3 ... OK
Starting kernel ...
What can I do to stop this randomness?
Jorge
Re: Deephi image get stuck in Starting Kernel for ZCU102
@jorlampThe first things that I would do are:
[1] Test with a different SD card.  I have used both Kingston and Sandisk cards with good results.  I am not aware of any issues, but the behaviour that you are seeing seems odd.
[2] Try the latest ZCU102 image file:  www.deephi.com/assets/2018-10-11-ZCU102-desktop-stretch.img.zip
[3] Confirm that all of the power rail LEDs are on.  It might be useful to snap a picture for both a good and bad boot to compare.  It is easy to not notice that one of the rails didn't come up properly.
[4] Reprogram the Maxim PMICs on the board.
https://www.xilinx.com/support/answers/66811.html
https://www.maximintegrated.com/en/storefront/search_result.html?type=sample&sampleSearchField=MAXPOWERTOOL002
Hope this helps!
--Quenton
