Observer jorge_2015
Error using decent command
I have downloaded the DP-8020 DNNDK from DeePhi web page (deephi_dnndk_v2.06_beta_DP-8020) and I am following the instructions in docs folder but after installing decent and dnnc tools I am having this error when I run the decent_resnet50.sh example:
./decent_inception_v1.sh
WARNING: Logging before InitGoogleLogging() is written to STDERR
E1007 13:48:37.625969 19663 decent_q.cpp:104] Available caffe actions:
E1007 13:48:37.626034 19663 decent_q.cpp:107]   check
E1007 13:48:37.626041 19663 decent_q.cpp:107]   deploy
E1007 13:48:37.626046 19663 decent_q.cpp:107]   finetune
E1007 13:48:37.626051 19663 decent_q.cpp:107]   quantize
E1007 13:48:37.626056 19663 decent_q.cpp:107]   test
F1007 13:48:37.626061 19663 decent_q.cpp:109] Unknown action: fix
*** Check failure stack trace: ***
./decent_inception_v1.sh: línea 13: 19663 Aborted                (`core' generated) decent fix -model ${model_dir}/float.prototxt -weights ${model_dir}/float.caffemodel -output_dir ${output_dir}
Is decent fix supported for this version? Or do I need to launch another command for quantization?
Thanks!
Jorge
PD: The website is very slow!!
Observer jorge_2015
Re: Error using decent command
Okey,
I have been launching decent executable for deephi_dnndk_1.10_beta and deephi_dnndk_v2.06_beta_DP-8020 and I have realised that:
  • For deephi_dnndk_1.10_beta fix command exists.
~/Deephi/deephi_dnndk_1.10_beta/host_x86/pkgs/bin$ ./decent
decent: command line brew
usage: decent <command> <args>
commands:
  fix             transform float model to fix (need calibration with dataset) and deploy to DPU
example:
  1. fix:                    ./decent fix -model float.prototxt -weights float.caffemodel -gpu 0
  2. fix with auto test:     ./decent fix -model float.prototxt -weights float.caffemodel -gpu 0 -auto_test test_iter 50
  3. fix with diffs method:  ./decent fix -model float.prototxt -weights float.caffemodel -gpu 0 -method 1
  Flags from tools/decent.cpp:
    -auto_test (Optional: test after calibration, need test dataset) type: bool
      default: false
    -calib_iter (Optional: max iterations for fix calibration) type: int32
      default: 100
    -data_bit (Optional: data bit width after fix) type: int32 default: 8
    -gpu (Optional: the GPU device id for calibration and test) type: string
      default: "0"
    -ignore_layers (Optinal: list of layers to be ignore during fix,
      comma-delimited) type: string default: ""
    -ignore_layers_file (Optional: YAML file which defines the layers to be
      ignore during fix, start with 'ignore_layers:') type: string default: ""
    -input_blob (Optional: name of input data blob) type: string
      default: "data"
    -method (Optional: method for fix, 0: OVERFLOW, 1: DIFF_S) type: int32
      default: 0
    -model (The model definition protocol buffer text file.) type: string
      default: ""
    -output_dir (Optional: Output directory for the fix results) type: string
      default: "./fix_results"
    -ssd (Optional: SSD testing with three AP computing styles: 11point,
      MaxIntegral, Integral) type: string default: ""
    -test_iter (Optional: max iterations for test) type: int32 default: 50
    -weights (The pretrained float weights for fix.) type: string default: ""
    -weights_bit (Optional: weights and bias bit width after fix) type: int32
      default: 8
  • For deephi_dnndk_v2.06_beta_DP-8020 fix command doesn't exist.
~/Deephi/deephi_dnndk_v2.06_beta_DP-8020/host_x86/pkgs/ubuntu16.04/cuda_9.0_cudnn_v7.0.5$ ./decent
usage: fix_tool <command> <args>
commands:
  quantize        transform float model to fix (need calibration with dataset) and deploy to DPU
  deploy          deploy finetuned model to DPU
  finetune        train or finetune a model
  test            score a model
example:
  1. quantize:                      ./decent_q quantize -model float.prototxt -weights float.caffemodel -gpu 0
  2. quantize with auto test:       ./decent_q quantize -model float.prototxt -weights float.caffemodel -gpu 0 -auto_test -test_iter 50
  3. quantize with method 0:        ./decent_q quantize -model float.prototxt -weights float.caffemodel -gpu 0 -method 0
  4. finetune quantized model:      ./decent_q finetune -model fix_results/float_train_test.prototxt -weights fix_results/float_train_test.caffemodel -gpu 0
  5. deploy finetuned fixed model:  ./decent_q depoly -model fix_train_test.prototxt -weights fix_finetuned.caffemodel -gpu 0
  Flags from tools/decent_q.cpp:
      default: false
      default: 100
    -classNUM (The number of segmentation classes.) type: int32 default: 19
      default: "0"
    -include_ip (Whether the InnerProduct layer is quantized.) type: bool
      default: false
      default: "data"
    -keep_bn (Optional: remain BatchNorm layers) type: bool default: true
      default: 1
      default: ""
    -quan_bits (The number of bits used in quantization.) type: int32
      default: 8
    -segmentation (Optional; Segmentation testing using metric:classIOU)
    -sigmoided_layers (Optinal: list of layers before sigmoid operation, to be
      fixed with optimization for sigmoid accuracy) type: string default: ""
    -solver (The solver for finetuning or training.) type: string default: ""
      default: 8
    -yolo (Optional: YOLO testing with three AP computing styles: 11point,
Please be careful mixing versions and writing documentation
@jorge_2015, from this release and later on, decent fix has been changed to decent quantize.
Please change decent fix in the decent_inception_v1.sh to decent quantize
Andy
