Visitor daedeepya.y
Error when running the object detection SSD model
I am trying to run the Object detection SSD caffe model on Deephi DNNK using a ZCU102 board. But I get the following error when I run the compiler(./dnnc),
Compiling network: ObjectDetection
[DNNC][Error] Unrecognized layer type [Normalize], Maybe you can delete it in deploy.prototxt and try again.
[DNNC][Error] Parsing layer graph failed.
When I try deleting this layer from the deploy.prototxt file, I get the following error,
[DNNC][Error] Unrecognized layer type [Reshape], Maybe you can delete it in deploy.prototxt and try again.
After deleting the reshape layer, I still get the following error,
[DNNC][Warning] layer [mbox_conf_softmax] is not supported in DPU, deploy it in CPU instead.
4: 1-0-11 Field is too long!
./dnnc_mobilenet.sh: line 13: 31155 Aborted                 (core dumped) dnnc --prototxt=${model_dir}/deploy.prototxt --caffemodel=${model_dir}/deploy.caffemodel --output_dir=${output_dir} --net_name=${net} --dpu=4096FA --cpu_arch=arm64
Are the Normalize and Reshape caffe layers not supported? Also, what does field too long mean?
Thank you for all the assistance,
Daedeepya Y
Visitor dsskjelb
Re: Error when running the object detection SSD model
I have the same issue - any updates here? It would be great to test out other algorithms on the DeePhi platform, but having issues like this one when I try.
Visitor lixun123
Hi!
      I have the same problem. Have you solved this problem?Can you tell me how to solve it?
Thans!
You'll need to replace the Normalize layer with BatchNorm and Scale layers because the DPU does not support Normalize. In the original SSD model, this is usually called "conv4_3_norm".
The following steps can be used to replace the layer:
1) Delete the Normalize layer named "conv4_3_norm"
2) Insert the Batchnorm layer and scale layer between "conv4_3" and "relu4_3" layers. The layers should look something like this:
layer{
type: "BatchNorm"
bottom: "conv4_3"
top: "conv4_3"
param {
lr_mult:0
decay_mult:0
param{
lr_mult:0
decay_mult:0
param{
lr_mult:0
decay_mult:0
layer{
type: "Scale"
bottom:"conv4_3"
top: "conv4_3"
param{
lr_mult:1
decay_mult:0
param{
lr_mult:1
decay_mult:0
scale_param{
bias_term:true
3) now you'll need to rename the connections on the other layers for bottom: "conv4_3_norm"  to bottom: "conv4_3"
4) the reshape layer should have the following parameter included in it (during training)
include{
phase:TEST
5) The last 5 layers of the SSD model should have the same parameter so that they are not included in the trained model.  These include mbox_conf_reshape (Reshape), mbox_conf_softmax (Softmax), mbox_conf_flatten (Flatten), detection_out (DetectionOutput), and detection_eval (DetectionEvaluate) which
6)  After making these modifications, you'll need to retrain the model because they make structural changes to the .caffemodel.
The resultant prototxt and caffemodel should be usable by DNNDK.
Visitor dsskjelb
Thanks for guidance - re-training makes sense. I just wondered if it is correct to have the same name for top and bottom in the Batchnorm and Scale layers as you have in step 2?
Yes, this should be the correct configuration of these layers.  Please follow up with a post to let us know if this works for you!
JC
Visitor dsskjelb
Thanks - yes I think it works as you describe it; at least the decent tool manages to do quantization and pruning. I tried to do this on googlenet rather than an SSD algorithm right now - and after replacing Normalize with BatchNorm and Scale, I get this error from the DNNC compiler (version v2.03) :
dnnc version v2.03
DPU Target : v1.3.0
Build Label: Dec 11 2018 11:52:13
Copyright @2018 Xilinx Inc. All Rights Reserved.
dnnc --prototxt=quantize_results/deploy.prototxt --caffemodel=quantize_results/deploy.caffemodel --net_name=googlenet --dpu=4096FA --cpu_arch=arm64 --output_dir=dnnc_output --dump=all
[DNNC][Warning] Only max pooling is supported, but [pool5_7x7_s1] layer has average pooling type.
[DNNC][Warning] layer [pool5_7x7_s1] is not supported in DPU, deploy it in CPU instead.
[DNNC][Warning] layer [prob] is not supported in DPU, deploy it in CPU instead.
[DNNC][Error] Failed to find available backend optimization pattern for current layer [pool2_bn].
The layer it complains about is the Normalize and Scale layer - snipping out surrounding code in quantized deploy.prototxt here :
layer {
type: "ReLU"
bottom: "conv2/3x3"
top: "conv2/3x3"
phase: TRAIN
layer {
type: "Scale"
bottom: "conv2/3x3"
top: "conv2/3x3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 1
decay_mult: 0
phase: TRAIN
scale_param {
bias_term: true
layer {
type: "Pooling"
bottom: "conv2/3x3"
top: "pool2/3x3_s2"
phase: TRAIN
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
I think we generally insert the batchnorm/scale combination in between the convolutional and relu layers.  It's hard to tell from the code snippet where this was inserted.
A second note is that when deploying inception_v1, I believe scale layer is not used with batchnorm.  I believe something like the following will be used to directly replace the Normalize layer where "conv2/3x3_raw" is the top connection for conv2/3x3 convolution layer:
layer{
type: "BatchNorm"
bottom:"conv2/3x3_raw"
top:"conv2/3x3"
param {
lr_mult:1
decay_mult:0
param {
lr_mult:1
decay_mult:0
param {
lr_mult:0
decay_mult:0
param {
lr_mult:0
decay_mult:0
batch_norm_param {
scale_filler {
type: "constant"
value: 1
bias_filler{
type: "constant"
value:0
