F0117 20:26:37.153761 15086 bbox_util.cu:824] Check failed: match_index[p] < gt_bboxes.size() (1 vs. 1)
When I use the decent.sh, I have this error in the figure.
I have modified the prototxt file and trained the model with PASCAL VOC dataset as: https://forums.xilinx.com/t5/Deephi-DNNDK/SSD-support-in-DNNC/m-p/896797. And I have upload related files in Attached.
I really need your help to solve this problem. Thank you very much!
Re: F0117 20:26:37.153761 15086 bbox_util.cu:824] Check failed: match_index[p] < gt_bboxes.size() (1 vs. 1)
Hi @howtocodewang_,
I believe you need to remove your MultiBoxLoss layer as this is likely causing the issues.  I would just remove it and then retry.
It also looks like you have two AnnotatedData input layers (one for test and one for train).  For the quantization/compilation process, I would remove the "train" AnnotatedData layer and use something like the following instead to specify a path to the calibration data (change the paths to point to your calibration.txt and images):
layer {
type: "ImageData"
top: "data"
top: "label"
include {
phase:TRAIN
transform_param {
crop_size: 300
mean_value: 104.0
mean_value: 117.0
mean_value: 123.0
resize_param {
prob: 1.0
resize_mode: WARP
height: 300
width: 300
interp_mode: LINEAR
interp_mode: AREA
interp_mode: NEAREST
interp_mode: CUBIC
interp_mode: LANCZOS4
image_data_param {
source: "./data/imagenet_320/calibration.txt"
root_folder:"./data/imagenet_320/calibration_images/"
batch_size: 10
shuffle: true
Hi @jcory,
Your solution is really helpful for me. decent.sh can work after removing my MultiBoxLoss layer. Thanks a lot.
However, I have another question when I try to deploy the quantized model (the .elf file) on the ZCU102 board. I modified the samples called video_analysis. But I got this error.
I provide the modified main.cc file. Can you give me more information and figure out my faults.
Thanks!
@jcory This attached is the modified main.cc file.
