Visitor mghodsi
Quantizing a network using DECENT
I am trying to use DECENT to quantize resnet50 model retrieved from their official github page (https://github.com/KaimingHe/deep-residual-networks) trained for imagenet 2015. Using their caffemodel and prototxt files and following the procedure in DeePhi DNNDK v2.07 guide, it seems that the loss for calibration remains a constant value of 87.3365. It still produces the output files and then using DNNC tool I can create necessary .elf files. However the results are off when I test the network on a ZCU102 board.
Please note that I modified the prototxt input layer to ImageData type with a path to a calibration set and modified the last layers accordingly based on the examples provided in DNNDK samples. Can someone tell me if there is anything I am missing during quantization?
Thanks!
Tags (3)
Re: Quantizing a network using DECENT
@mghodsiAttached is the float prototxt of Resnet50 for your reference. It also includes the path to the calibration images from ImageNet dataset. You may need to point it to the path of your calibration images.
