Observer jorge_2015
SDSoC/Vivado 2018.3 and DPU IP
I have downloaded SDSoC and Vivado 2018.3 new release but I am not able to see this DPU IP integrated like it is said in this post, where can I find it?
I have also read in the ug1294-sdsoc-rnil this:
• Enhanced support for machine learning with the DeePhi data-processing unit (DPU) that includes support for multiple software entry points to control the DPU and tool flow updates.
• Enhanced support for the DeePhi ML stack as a C-Callable IP library.
Can somebody point me out with some resources to create my own fpga designs using this DPU IP Core?
Thanks in advance for your help,
Jorge
Re: SDSoC/Vivado 2018.3 and DPU IP
@jorge_2015C-callable DPU IP package is not pre-installed in SDSoC 2018.3. It will be published in Jan in the form of a separate package. You will download it and unzip to a local folder. Then you can create SDSoC application with selected platform, such as ZCU102 revision platform, then you can import the source files to the workspace and set the include paths for header and libraries files. After that, you can build it to generate the SD card image.
