Observer kohsenglee
SDSoC face detection build fails for ug1331
I am trying to build face detection in ug1331. I already built dpu_zcu102 bitstream and proceeded to build face detection demo. I am getting the following error but do not know where to change. /home/yijianlong is the default path in the SDSoC project which cannot be modified in the C/C++ build settings.
Please advise!
11:20:59 **** Incremental Build of configuration Debug for project gstsdxfacedetect ****
make all
Building file: ../src/densebox.cpp
Invoking: ARM A53 Linux g++ compiler
aarch64-linux-gnu-g++ -Wall -O2 -I"/home/chriskoh/work/sdsoc_dpu/include" -I/home/yijianlong/platform/2018.3/zcu102-rv-ss-2018-3/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include -I/home/yijianlong/platform/2018.3/zcu102-rv-ss-2018-3/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include/glib-2.0 -I/home/yijianlong/platform/2018.3/zcu102-rv-ss-2018-3/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/lib/glib-2.0/include -I/home/yijianlong/platform/2018.3/zcu102-rv-ss-2018-3/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/include/gstreamer-1.0 -I/home/yijianlong/platform/2018.3/zcu102-rv-ss-2018-3/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux/usr/lib/gstreamer-1.0/include -c -fPIC -fpermissive -fmessage-length=0 -MT"src/densebox.o" --sysroot=/home/yijianlong/platform/2018.3/zcu102-rv-ss-2018-3/zcu102_rv_ss/sw/a53_linux/a53_linux/sysroot/aarch64-xilinx-linux -MMD -MP -MF"src/densebox.d" -MT"src/densebox.o" -o "src/densebox.o" "../src/densebox.cpp"
In file included from /opt/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.3.1/aarch64-linux-gnu/bits/c++config.h:533:0,
                 from /opt/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.3.1/type_traits:38,
                 from /opt/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.3.1/ratio:38,
                 from /opt/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.3.1/chrono:38,
                 from ../src/densebox.h:52,
                 from ../src/densebox.cpp:49:
/opt/Xilinx/SDK/2018.3/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.3.1/aarch64-linux-gnu/bits/os_defines.h:39:10: fatal error: features.h: No such file or directory
src/subdir.mk:21: recipe for target 'src/densebox.o' failed
 #include <features.h>
compilation terminated.
make: *** [src/densebox.o] Error 1
11:20:59 Build Finished (took 58ms)
Chris
Re: SDSoC face detection build fails for ug1331
Looks like you probably need to change the referenced platform to the one local on your machine, and also set SYSROOT properly.
Participant dehim
I'm on windows. I had set SYSROOT 'correctly' but it still gave the same error. What helped for me was to change SYSROOT from C:\path\to\sysroot to ${=C:}\path\to\sysroot.
EDIT: ${=C:} doesn't work. Try ${SystemDrive} instead. SYSROOT has to be on C drive for this to work though.
Hello sir,
I am facing the same problem.
I am using SDSoC 2018.3 and zcu102-rv-ss-2018-3-dnndk platform as mentioned in latest ug1331
Environment setting
sysroot_pic.PNGand build console log
Please let me know if any information is needed..
Thanks in advance
Participant dehim
Apparently ${=C:} doesn't work either. ${SystemDrive} does work for me, but SYSROOT has to be on C drive in that case. For me that's no problem, but I get that you might want to have sysroot on a different drive. Can you try to move sysroot to C drive and see if it works when you use ${SystemDrive}?
Thanks a lot. It works for me too..
Observer liangxinyu86
Hi, can you  give us  a  screenshot   about  the  SYSROOT  of  SDx.  I dont  know how to do . I am facing  the  same problem.
Thank you  very much !
In windows PC system
Control Panel -> System and Security -> System -> Advanced system settings -> Environment Variables and then click to add new one -
Variable value : ${SystemDrive}\zcu102-rv-ss-2018-3-dnndk\zcu102_rv_ss\sw\a53_linux\a53_linux\sysroot\aarch64-xilinx-linux\
Note: zcu102-rv-ss-2018-3-dnndk folder need to locate in C drive
