the DNNDK in Ultra96 board can't display
as below, i can not test the samples in ultra96 board
Screenshot from 2019-01-09 16-22-26.pngScreenshot from 2019-01-09 16-17-39.png
Re: the DNNDK in Ultra96 board can't display
thanks, i've solve the problem, change the connection way to ssh, thanks anyway
Are you connected over the serial port? If so, you need to set the DISPLAY variable properly before running the application:
export DISPLAY=:0.0
Terry
how to link the ssh to the ultra96 board? i have the same question with you , and when the system up , it display "wlan0 link is not ready and cannot open display,thanks!!
How are you connected to the board? Do you have a DisplayPort monitor connected?
Terry
yes I have,the log information is below,
I am using the MobaXterm in Windows, connect the board via ssh
Using the MobaXterm in Windows
I am not using the wlan, I am using the eth0,
through the USB Port, then transform to Eth
Observer troublesig
Have you solved this problem? I also encountered this problem today.
Please review the solution above, and also the thread below:
https://forums.xilinx.com/t5/Deephi-DNNDK/wlan0-link-is-not-ready-with-ultra96-board/td-p/934285
Observer troublesig
The DNNDK in Ultra96 board can't display,how do you connect to the network and connect to ssh?
You can use a USB network adapter.
Or you can follow the instructions here to setup the wireless network from the command line.  I was successful with the WPA instructions:
https://www.linux.com/learn/how-configure-wireless-any-linux-desktop
Here is what it boiled down to for my situation:
1st time only:
wpa_passphrase <SSID> <PASSWORD>
copy the generated text into a new file called /etc/wpa_supplicant.conf
Subsequent boots:
wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
dhclient wlan0
OR for static IP
ifconfig wlan0 <ipaddress> netmask 255.255.255.0
Observer troublesig
Thanks a lot, I can now connect to the wireless network. But still can't be displayed on the display
I would try a couple of different monitors and cables.  The display should come up at boot automatically.
Terry
Observer troublesig
Is this a problem with the display or cable? The monitor I use is DELL SE2416H.
不知道你是不是中国人哈
是这样的,深鉴的镜像在Ultara96板子上并不能通过DVP或者那个HDMI等方式输出,它的软件设置是连接上网络,以一种类似于VNC的方式进行输出。先要通过SSH连接上板子,我亲测MobaXterm这个软件可以使用,Putty不可用。然后在执行软件的时候,就会在主机上重新弹出一个对话框,显示对应的图片。板子上没有以太网接口,我使用了一个USB转以太网HUB,USB接板子,以太网端接主机。如果你不是中国人,自己翻译吧。。。。。
Observer troublesig
哈哈哈,多谢多谢,我试试,请问方便加个联系方式吗,便于交流,我的微信号是TroubleSignal,非常感谢
