2018.2 IP Packager can't disable source file
I tried right-click > disable file and Property uncheck "Enabled". Either method marks the file is disabled. But after Re-Package IP, and reopen, the disabled file is enabled again.
So the file disable doesn't seem to be useful for me for now. Am I doing something wrong?
Please comment.
Re: 2018.2 IP Packager can't disable source file
@legendbb,
The changes of disabling files which you are making are in temp project. You need to use remove file option in Files groups under packager to see the changes getting reflected in repackaged IP.
--Syed
@legendbb,
By reopen, do you mean opening the project which has custom IP? You need to reset and regenerate the IP output products and also check if there is any change in IP instantiation template.
--Syed
Hi, Syed,
Thanks for reply. I reopen the IP project in IP packager. I tried remove file from the IP project and make sure file inclusion in IP GUI File Groups is updated, then repack. Then I can move on to generate the instantiation design.
I started the IP project by: Tools > Create and Package New IP > Package a specified directory
Maybe I shall try other IP workflow.
@legendbb,
--Syed
