Visitor emailbox2000
3rd party boards with no file board, how to work with these?
I've bought a Parallella board and there is no file board in the internet or in Vivado to choose, when creating new project.
So what should I do when I want to implement my logic on this board? I know I can select the appropriate zynq device instead of the board but how can I configure the other things to be suitable for programming my board?
Basically what things is important to configure when we are trying to work with 3rd parties board and there is no file board to select? and how can we configure these things?
Thank you
Scholar u4223374
Re: 3rd party boards with no file board, how to work with these?
The Parallella schematic is on their website; that tells you the voltage supplied to each bank and where each pin connects. You just need to decide which of those pins you plan to use, and assign suitable IOSTANDARD settings.
Hello @emailbox2000,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Thanks. Could anyone also introduce some tutorial about how to do this in vivado?
