Observer alexrp92
AXI GPIO all output configuration doesn't work
Hi all,
I am trying to make a communication from linux to my FPGA using AXI gpio, for this reason, I just need to cnfigure 1 port as output GPIO_io_o[31:0]. The problem comeswhen I implement the AXI GPIO ip using a tcl script... I made a .tcl file which contains the following lines:
# AXI GPIO IP core
startgroup
create_bd_cell -type ip -vlnv xilinx.com:ip:axi_gpio axi_gpio_0
set_property -dict [list CONFIG.C_ALL_INPUTS {0} CONFIG.C_ALL_OUTPUTS {1}] [get_bd_cells axi_gpio_0]
endgroup
As a result. the ip is created in the diagram page at vivado's but the GPIO is configured as all inputs instead of all outputs... Besides, if I write in the tcl console (after the creation of the gpio ip) the following line:
the ip changes to all output.. so I don't understand why it doesn't work from the script..
thanks!
Re: AXI GPIO all output configuration doesn't work
I did a quick test and instantiated an axi_gpio in IPI. I then exported the bd. This is the code for creating that ip from the resulting .tcl file. I then includes in a .tcl file of it's own and sourced that file. The resulting instantiated axi_gpio was configured for all outputs.
# Create instance: axi_gpio_0, and set properties
set axi_gpio_0 [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_gpio:2.0 axi_gpio_0 ]
set_property -dict [ list \
CONFIG.C_ALL_OUTPUTS {1} \
] $axi_gpio_0
Steve Markgraf - Distinguished FPGA Design & Support Engineer E5-E
www.designlinxhs.com
Which version of Vivado are you running?
Observer alexrp92
2019.1
] $axi_gpio_0
