AXI Interconnect redandunt ports in Address Editor -> how to remove?
Hi All,
I need some explanation regarding the AXI Interconnect ports mapping.
As you could see, Address Editor refers to M03 and M04 ports, which are not actually exist (see the second snapshot below). So, how to remove these ports from the Address Editor (from the Block Design they have been removed)?
If I leave the ports as they are, I'm receiving the "Duplicate Node Name" error while creation a petalinux image (see the third snapshot).
Thank you
check this related ARs
http://www.xilinx.com/support/answers/60971.html
https://forums.xilinx.com/t5/Welcome-Join/Device-tree-error-Duplicate-label/td-p/300477
Thanks and Regards
Balkrishan
did you run validate?
