AXI bus not being connected in block disagram mode
All
    I'm using Vivado 2015.4 on a MicroZed board.  To create a sample design I'm following the design creation example described in UG940 for a Zynq processor.  I've added the Zync processor with a simple Hello World example project and that works fine.  I go back into the block diagram and I add the AXI GPIO and AXI BRAM Controller as instructed.  When I select the Block Automation function the AXI bus connections do not show up in the connection options.  I get the following warning:
WARNING: [board_rule:/axi_gpio_0-100] Board automation did not generate location constraint for /axi_gpio_0/GPIO. Users may need to specify the location constraint manually.
    How do I get the Block Automation function to connect the AXI bus?
         Marv
Re: AXI bus not being connected in block disagram mode
All:
     The problem has been solved.  If I double-click on the ZYNQ7 processor block, at the bottom of the diagram is a block called "32b GP AXI Master Ports".  When I open this sub-menu I needed to turn on the "M AXI GP0 interface".  This is a check box.  Once this was enabled everything worked as expected.
     Marv
All:
     Marv
