Observer cerg19
Add vhdl file in Vivado diagram
Hi.
I create simple project from Xilinx IP in Vivado 2013.4. I add all IP in Diagram and connect them to each other. I create custom vhdl file and want to add this file as component in diagram and connect it to others IP.
How I can create schematic block from my vhdl file and add it to my diagram?
Re: Add vhdl file in Vivado diagram
Package your design using Vivado IP packager. After this add the IP repository to your block design project IP catalog. After this you can see your custom IP in "ADD IP" of block design.
Check these for more details
chapter-8 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug896-vivado-ip.pdf
lab-3 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug939-vivado-designing-with-ip-tutorial.pdf
Deepika.
Deepika.
Deepika.
Deepika.
Observer asrarhashmitud
I want to ask further on this. I got the point that we can at custom vhdl after packaging and all that.
My question is that my vhdl is under designing/testing phase so every time i have to re package it and then re instantiate it which takes a lott of t ime. Does there exist any simpler way for doing this?
tHanks
Asrar
Visitor m.alkadi
I have this problem as well. Actually, in GUI mode Vivado can detect changes in the source files. The IP can be then updated with a couple of clicks without repackaging. But I didn't find a solution in tcl mode.
Observer caryan
For other internet searchers out there, as of Vivado 2016.1 it is much easier to add a bare HDL file to a block design by adding a module rather than jumping through hoops to package it up as IP. Vivado does a decent (but not perfect) job of just inferring the interfaces. See "Chapter 12: Referencing RTL Modules" in UG994.
But beware!!!
If you happen to have instantiated some IP module in that RTL code, you will get an error telling you that referencing of IP is not enabled.
I have also had little luck with RTL files instantiating components in .ngc files. They pass synthesis, but fail on implementation with the message that they are black boxes, and vivado cannot find the underlying instance.
A vivado project with plain RTL toplevel (not block diagram) would find those .ngc files
Observer caryan
Yeah, there is a long list of limitations:
• The RTL module definition cannot include other IP definitions (XCI), netlists (EDIF or
DCP), nested block designs (BD) or another module that is set as out-of-context (OOC)
inside the RTL module.
• VHDL and Verilog are the only supported languages for module definition.
TIP: SystemVerilog and VHDL 2008 are not supported for the module or entity definition at the
top-level of the RTL module.
We ran into the ngc one too as it's not explicitly listed but I assume it falls under the no netlists limitation and the VHDL-2008 is another annoying limitation for us.
Thank you very much for this post and the solution.
